PID autotune
Does the latest Repetier firmware support Autotune?
If I change the thermistor do I need to run autotune or is changing the Thermistor setting to type  "8" sufficient? Type 8 is what the manufacturer recommends.
Where in the firmware would I make these changes?
Thanks, Jim G
  • You change EXT0_TEMPSENSOR_TYPE or Temperature Sensor as we call it in config tool. Changing this requires recompiling firmware.
    We have autotune for PID but it does not depend on thermistor used if it was done with right temperatures before.
