Different slicer in one gcode
i want to use different slicer option in one gcode program. Is it possible to choose different sliceroptions for different areas of layers?
Tim
  • Not in host directly. In Slic3r if run with plater enabled you can load a stl that defines a new region and assign different parameter to that region and slice. Then load gcode into host to print.
    I think that is good. Where can i find the "plater" option to enable it?
  • In slicer tab select Manager and then Slic3r. Last option is to show or hide plater in slic3r.
    Thank you for your help. I can work with this option.
  • Hello to all!! Please help )) I did not get the right shape of result( the top side is moved to one side with about 15mm and continued to print... the result is like this one image
    Could be endstop crosstalk - try with always check endstops disabled. Or one jerk was to hard loosing steps or motor current too low or it simply got cought by a part warping up.
