Sparse first layer - it is necessary to increase the flow of plastic to 135%
Hello!
Thank you very much for your programs of 3D-printers!
On my printer has a problem that prevents normal print.
I do not know, in case the firmware or not.
So: 0.5mm nozzle, firmware version 0.91R8, BABYSTEPPING off.
Before start printing, I checks that in place of the print nozzle regard to the table. When lifting the nozzle up to 0.1 mm - it breaks away from the table.
Problem: When printing the first layer it turns sparse, the line did not touch each other. As it happens with any slicer.
Tried thickness of the first layer is 0.16; 0.2; 0.3 always puts sparsely first layer.
When printing 2-th and the following layers are placed properly, tightly.
For the first layer only helps increase the flow of plastic by hand to 135%, and for the next layer is necessary to again set manually feed the plastic 100%. In this case, all the layers are printed well.
How is it possible to solve the problem of printing the first layer? This incorrect configuration of firmware or not?
  • Most slicers have a setting where you can set 'first layer' height and extrusion rate and allso first layer speed.
    It is best to set a higher 1st layer and extrusion to get better adhesion to the bed.
