Подскажите пожалуйста что за ошибки у меня и что я сделал не так. Заранее спасибо.
edited February 12 in Bug Reports
10:31:16.193 : Printer reset detected - initalizing
10:31:16.193 : start
10:31:16.193 : echo: External Reset
10:31:16.194 : Marlin1.0.0
10:31:16.194 : echo: Last Updated: Aug 25 2016 15:25:07 | Author: (none, default config)
10:31:16.194 : Compiled: Aug 25 2016
10:31:16.194 : echo: Free Memory: 11889  PlannerBufferBytes: 1232
10:31:16.194 : echo:Stored settings retrieved
10:31:18.576 : echo:SD init fail
10:31:18.650 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
10:31:18.652 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
10:31:18.652 : echo:Active Extruder: 0
10:31:18.652 : Begin file list
10:31:18.652 : End file list
10:31:18.652 : Error:checksum mismatch, Last Line: 1
10:31:18.652 : Resend: 2
10:31:18.720 : Error:Line Number is not Last Line Number+1, Last Line: 1
10:31:18.720 : Resend: 2
10:31:18.732 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:X3A_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
10:31:18.734 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
10:31:18.734 : echo:Active Extruder: 0
10:31:18.734 : Begin file list
10:31:18.734 : End file list
10:31:18.769 : Error:No Checksum with line number, Last Line: 11
10:31:18.769 : Resend: 12
10:31:18.781 : Error:Line Number is not Last Line Number+1, Last Line: 11
10:31:18.781 : Resend: 12
10:31:18.792 : Error:Line Number is not Last Line Number+1, Last Line: 11
10:31:18.792 : Resend: 12
10:31:18.804 : echo:Unknown command: "22"
10:31:18.804 : Error:No Line Number with checksum, Last Line: 11
10:31:18.804 : Error:Line Number is not Last Line Number+1, Last Line: 11
10:31:18.804 : Resend: 12
10:31:18.843 : echo:Active Extruder: 0
10:31:18.843 : Error:Line Number is not Last Line Number+1, Last Line: 17
10:31:18.843 : Resend: 18
10:31:18.855 : Error:No Line Number with checksum, Last Line: 17
10:31:18.855 : Error:Line Number is not Last Line Number+1, Last Line: 17
10:31:18.855 : Resend: 18
10:31:18.866 : Error:No Line Number with checksum, Last Line: 17
10:31:18.866 : Error:Line Number is not Last Line Number+1, Last Line: 17
10:31:18.866 : Resend: 18
10:31:18.878 : Error:No Line Number with checksum, Last Line: 17
10:31:18.878 : Error:Line Number is not Last Line Number+1, Last Line: 17
10:31:18.878 : Resend: 18
10:31:35.278 : Reduced visual quality for better framerates and to protect print quality.
10:31:35.279 : You can disable this in Config->Preferences->Basic Settings->Behaviour.
10:34:01.052 : Печать слоя 1 из 50
10:34:34.635 : Reduced visual quality for better framerates and to protect print quality.
10:34:34.635 : You can disable this in Config->Preferences->Basic Settings->Behaviour.
10:34:58.967 : Печать слоя 2 из 50
10:35:45.222 : Печать слоя 3 из 50
10:36:28.638 : Печать слоя 4 из 50
10:37:15.911 : Печать слоя 5 из 50
10:37:46.394 : Печать слоя 6 из 50
10:38:14.750 : Печать слоя 7 из 50
10:38:40.338 : Disabled additional filament drawing for better framerates and to protect print quality.
10:38:40.338 : You can disable this in Config->Preferences->Basic Settings->Behaviour.
10:38:43.220 : Печать слоя 8 из 50
10:39:11.378 : Печать слоя 9 из 50
10:39:39.736 : Печать слоя 10 из 50
10:40:08.179 : Печать слоя 11 из 50
10:40:36.327 : Печать слоя 12 из 50
10:41:04.684 : Печать слоя 13 из 50
10:41:33.133 : Печать слоя 14 из 50
10:42:01.301 : Печать слоя 15 из 50
10:42:29.645 : Печать слоя 16 из 50
10:42:58.104 : Печать слоя 17 из 50
10:43:26.265 : Печать слоя 18 из 50
10:43:54.630 : Печать слоя 19 из 50
10:44:23.088 : Печать слоя 20 из 50
10:44:51.246 : Печать слоя 21 из 50
10:45:19.594 : Печать слоя 22 из 50
10:45:48.042 : Печать слоя 23 из 50
10:46:16.197 : Печать слоя 24 из 50
10:46:44.563 : Печать слоя 25 из 50
10:47:13.015 : Печать слоя 26 из 50
10:47:41.177 : Печать слоя 27 из 50
10:48:09.524 : Печать слоя 28 из 50
10:48:37.991 : Печать слоя 29 из 50
10:49:06.154 : Печать слоя 30 из 50
10:49:34.499 : Печать слоя 31 из 50
10:50:02.963 : Печать слоя 32 из 50
10:50:31.117 : Печать слоя 33 из 50
10:50:59.467 : Печать слоя 34 из 50
10:51:27.940 : Печать слоя 35 из 50
10:51:56.089 : Печать слоя 36 из 50
10:52:24.445 : Печать слоя 37 из 50
10:52:52.910 : Печать слоя 38 из 50
10:53:21.086 : Печать слоя 39 из 50
10:53:49.432 : Печать слоя 40 из 50
10:54:17.769 : Печать слоя 41 из 50
10:54:46.043 : Печать слоя 42 из 50
10:55:14.326 : Печать слоя 43 из 50
10:55:42.720 : Печать слоя 44 из 50
10:56:10.892 : Печать слоя 45 из 50
10:56:39.303 : Печать слоя 46 из 50
10:57:07.714 : Печать слоя 47 из 50
10:57:41.544 : Печать слоя 48 из 50
10:58:26.170 : Печать слоя 49 из 50
10:59:10.130 : Печать слоя 50 из 50
11:00:02.762 : Задача завершена в 12.02.2017 11:00
11:00:02.762 : Время печати:27 мин:20 с
11:00:02.762 : Отправлено строк:21518
