ramps-fd (arduino due) + 12864 Full graphic smart controller
1
Hi!
I connect to the Arduino due the rams-Fd V1.0  LCD adapter display 12864 (Full graphic) .
 It glows, but the hiring does not display anything. Flash version 0.92.
(A branch read, but have not figured out how to make it work)
Please help.
    You need to define the display manually. Find either in ui.h the right display and add a section for your board with pins matching (simple solution) or define it as custome display in uimenu.h. I think the problem is that we have no mapping for that board/display type available. If you have it working you can send it so we can add it for the future.
  • the user display earned (I have exactly the same Board , the adapter and the display).
    I insert rows into ui.h
        #define LCD_PINS_RS         16
        #define LCD_PINS_ENABLE     17
        #define LCD_PINS_D4         23
        #define LCD_PINS_D5         25
        #define LCD_PINS_D6         27
        #define LCD_PINS_D7         29
            #define BEEPER            37
          #define BTN_EN1           33
          #define BTN_EN2           31
          #define BTN_ENC           35
          #define SDCARDDETECT      49
    but nothing is changing.
    What am I missing?
  • edited February 5 Posts: 0
    Same problem, even not connecting to arduino due, but works on Marlin4Due
    It depends on where you set the pins. Also the names are for Marlin not repetier. So put them in your display with the same chip and add a section for ramps fd with pin names as used for the other cases. I don't have the board and also not that display also it might be compatible, in any way I can not test anything. You need to do that. All I can do is if someome has  a new working combination to insert it to our current DisplayList.h (ui.h in old versions).
