MKS LSD mini. Help!
Good day! Really respect your work and the firmware Repeater! I love that display https://ru.aliexpress.com/item/3d-printer-Reprap-LCD-MKS-MINI12864LCD-in-Front-mini-12864-smart-display-Reprapdiscount-controller-Full-Graphic/32708574939.html?spm=2114.13010608.0.0.EIPfzI
Can't connect it. Arduino Due + RAMPS-FD revA. Tried the firmware Marlin4Due - screen works, but no communication with the SD card. Using a display adapter card is connected to pins 4,74,75,76. But I don't want Marlin. Want your firmware. Have had a good experience. Tell me what to do? Help!
    We have no predefined pin configuration for that display+ Due. You can select manual display configuration and set chip type and pins as you wired it and it should work. But I don't know what the right setting is. You need to check what marlin uses or from display docs.
