Slic3r cannot compile G-Code
Hi there, I've trying to use REPetier with a mUVe, it uses an Arduino 2560. I get this error message whenever I try to get a G-Code for an object:
12:46:55.351 : <Slic3r> => Generating perimeters
12:46:55.369 : <Slic3r> Error in function new_from_config_width at src\Flow.cpp:9: Invalid flow height supplied to new_from_config_width()
12:46:55.369 : <Slic3r>   at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/XS.pm line 126
12:46:55.369 : <Slic3r>  Slic3r::Flow::new_from_width('Slic3r::Flow', 'width', '100%', 'role', 0, 'nozzle_diameter', 0.1, 'layer_height', 0, ...) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Region.pm line 54
12:46:55.369 : <Slic3r>  Slic3r::Print::Region::flow('Slic3r::Print::Region=HASH(0x3d056f8)', 0, 0, 0, 1, undef, 'Slic3r::Print::Object=HASH(0x3d00318)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Layer/Region.pm line 52
12:46:55.369 : <Slic3r>  Slic3r::Layer::Region::flow('Slic3r::Layer::Region=HASH(0x398f4e8)', 0) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Object.pm line 377
12:46:55.369 : <Slic3r>  Slic3r::Print::Object::make_perimeters('Slic3r::Print::Object=HASH(0x3d00318)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 416
12:46:55.369 : <Slic3r>  Slic3r::Print::__ANON__(0) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 388
12:46:55.369 : <Slic3r>  Slic3r::Print::__ANON__(2, 'CODE(0x41c36b0)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 417
12:46:55.369 : <Slic3r>  Slic3r::Print::process('Slic3r::Print=HASH(0x3afd1a8)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Simple.pm line 92
12:46:55.369 : <Slic3r>  Slic3r::Print::Simple::export_gcode('Slic3r::Print::Simple=HASH(0x3d0b1c8)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/cavaexecscript/slic3r.pl line 180
12:46:55.370 : <Slic3r>  require cavaexecscript/slic3r.pl called at <Packaged Modules>/Application::Loader line 1469
12:46:55.370 : <Slic3r>  Cava::Pack::Code::_run_packaged_script('cavaexecscript/slic3r.pl') called at <Packaged Modules>/Application::Loader line 1496
12:46:55.370 : <Slic3r>  Cava::Pack::Code::_run_doscript() called at <Packaged Modules>/Application::Loader line 1558
Not quite sure what the above means... Can you guys help me?
  • That is an internal error of slic3r. So I think you should ask te authors of it at www.slic3r.org We only include the package and have no insight in how it works.
