Connect via ssl to Repetier Server
Greetings,
I hope I didn't miss a previous answer but the search didn't seem to turn one up.  I have Repetier-Server Pro 0.80.3 setup behine nginx running ssl on a non-standard port.   I can connect to it just fine via browser - even from work so I know the proxy and the router are setup ok.   I was hoping to connect with Repetier Host though (remotely) to upload sliced gcode like I do when I'm at home.   However Repetier Host gives me an error when I try. (fail to connect).   Any ideas?
  • Host always assumes non secure connection, so connectug to 443 like https would will not work.
  • Is there any plan to support ssl for the connection?   Half the reason I use host and paid for Server was integration.    I won't permit non ssl web through my firewall though.    Currently limping along using the web interface but would really love to get back to host fronting for server.    Things like E-Stop from host didn't work last I checked though and hosts locks up every 2nd or 3rd upload to server I try to do.  SSL would be another big thing.
  • I have to check if host websocket library supports secure websocket. I never thought about using host remotely to a outside server. Always thought about web interface with nginx instead since it is not possible to get https certificate for local ips. That also means even if we allow https I have to disable certificate validation or make it a default option. Have to see what is possible.
