Delta printer and backlash compensation
I read a post from way back 2014 that backlash compensation was not supported for deltas - is this still the case?
If not how do I go about measuring each motor and adjusting it?
  • Backlash for delta is in deed not supported as it would work different and I don't think it woul dbe able to love anything. Further more all motors must have same steps per mm.
    What do you mean with measuring each motor?
  • If it worked I would have presumed the three motors would be slightly different and need to be compensated individually.
    However when its not available for deltas, its a moot point I guess. Thanks for clarifying though!
  • On delta you need same strain on all belts so all steps per mm remain the same.
