Auto bed leveling issue
I'm having a issue with the repetier bed leveling. Everything seems to setup up OK but when it's starts a print it starts outon the 1st layer with the nozzle on the bed like it should but when it moves any distance in x axis or y axis it seems like it raises up slowly 2 or 3 mms as if it's over compensating not sure what is going on with that any help would be appreciated I also have tried several different things firmware wise to fix it but no luck
  • Make sure bending correction is 0 in eeprom.
    What is your autolevel matrix? Normally all values are close to 1 or 0 which would be prefectly leveled.
    What did G32 S2 return as z values? If it things your bed is very tiltet that might happen, so you need to find out why the computation has that result, so check the log output when running the autolevel.
  • Bending correction is zero. I will do a Eeprom cleae and start over and I'll show info then
