The laser turns on and flashes at the beginning of each movement and then stays off until the end.
I have a kit RAMPS 1.4 Kit + LCD 12864 Display + Mega 2560 R3 and a laser connected in port
D10.And use latest firmware Repetier published.
How do I correct the following? The laser turns on and flashes at the beginning of each
movement and then stays off until the end...
  • Sounds like some other function (Extruder) uses the same pin and overwrites the signal. It is not allowed to use a pin for 2 different functions, that will cause your error pattern.
  • Problem solved.
    I changed on PINS.H
    I have no extruder, fan or hot bed
    Thank you
