Print support with PVA
My printer has a dual extruder, and I'd like to print an object with PVA as support material.
I use the Included Cura, but I did not found in the configuration setting tabs  a way to specifiy which extruder to use for printing support material.
In standard Cura, the option exist. It's called "double extrusion support" in "Support".
Did I miss something, or is this option not available in Repetier-cura ?
  • In extrusion tab is a dropdown "Support Extruder" which you can set for this.
