not working: M500 Store settings to EEPROM_SMART_RAMPS
I install Repetier-Firmware 0.92.9 version, not working: M500 Store settings to EEPROM
electronics  SMART Ramps 1,4,1
but this Vrsi http://reprap.org/wiki/File:SMART_RAMPS_RepetierDue_En.zip works,
but I need the 0.92.9 version
help me please
  • Board 408 has no eeprom. I see in reprap wiki that there are now boards that also have eeprom. If you have such a board, please copy the I2C/eeprom settings from RADDDS board (all in pins.h) and test if they work. Then I can make a new board for smart ramps with eeprom.
  • Yes that's right that's this piece of code inserted and it worked, thank you very much
    #define SDA_PIN     20      // 20 or 70
    #define SCL_PIN     21      // 21 or 71
    #define TWI_CLOCK_FREQ          400000
    // see eeprom device data sheet for the following values, these are for 24xx256
    #define EEPROM_SERIAL_ADDR      0x50   // 7 bit i2c address (without R/W bit)
    #define EEPROM_PAGE_SIZE        64     // page write buffer size
    #define EEPROM_PAGE_WRITE_TIME  7      // page write time in milliseconds (docs say 5ms but that is too short)
    // TWI_MMR_IADRSZ_1_BYTE for 1 byte, or TWI_MMR_IADRSZ_2_BYTE for 2 byte
    #define EEPROM_ADDRSZ_BYTES     TWI_MMR_IADRSZ_2_BYTE
    #define EEPROM_AVAILABLE 1
    You can also add Repetier-Firmware configuration tool here this LCD AZSMZ 12864 LCD with TF Card 3D printer smart controller control panel
    thank you very much :)>- :)>- :)>-
  • Don't have that display.Do you have a working ui.h config for that display that I can include?
  • edited December 2016
    here have to work, I checked!
    http://reprap.org/mediawiki/images/f/f1/ArduinoDUE_0.92.9.zip
    18 or CONTROLLER_GATE_3NOVATICA Gate Controller from 3Novatica
    19 or CONTROLLER_SPARKLCD Sparkcube LCD on RADDS
    20 or CONTROLLER_BAM_DICE_DUE  DAM&DICE Due LCD Display
    21 or CONTROLLER_VIKI2 Panucatt Viki2 graphic lcd
    24 or CONTROLLER_ZONESTAR = Zonestar P802M with LCD 20x4 and 5 ADC button keypad
    405 or CONTROLLER_FELIX_DUE Felix LCD für due based board
    25 or CONTROLLER_AZSMZ12864 AZSMZ 12864 graphic lcd
    #define FEATURE_CONTROLLER CONTROLLER_AZSMZ_12864
    /* You can have one keypad connected via single analog pin as seen on
     some printers with Melzi V2.0 board, 20x4 LCD and 5 buttons keypad. This must be
     the analog pin number! */
    #define ADC_KEYPAD_PIN -1
  • Thanks. Will include it in next dev update.
