0.80.0 crashes after verifying update
I am running version 0.80.0 and updating to 0.80.3 but the server gets to the point that it verifies the update and crashes. I can't update due to this issue... Kinda sucks as well because I payed for the pro version. Any ideas?
  • I guess you are using linux. As our download page states the update is broken. Log in manually and send
    sudo /usr/local/Repetier-Server/bin/RepetierInstaller /usr/local/Repetier-Server/etc/RepetierServer.xml
    then it should update correctly. From 0.80.3 on updates should work again as we found out how to modify systemd start script to not kill the updater.
