Do I always have to change EEprom bit #1 number to save config when I upload ?
#define EEPROM_MODE 2
After making config.h changes do I have to change the number 2 to something else to save it to the eeprom?
  • Eeprom stays the same. The idea is if you need to change something stored in eeprom that you do NOT need to upload. Instead change it in eeprom with eeprom editor. In parallel you could change it in config so in case eeprom is lost you have same data. But it is just a pain to upload instead changing directly.
    In addition with
    M502
    M500
    you can copy config values to eeprom any time you want even if you do not change EEPROM_MODE. EEPROM_MODE change just enforces this on first start.
