Soft & hard endstop modification
Hi repetier,
I have new problem.
I set min hardware endstop for x(shoulder) rotation, and max hardware endstop for y(elbow) rotation.
I set max software endstop for x and min software endstop for y in configuration.h
I add new function rotation() for x & y individual angle movement.
The problem i have is endstop is working on move cartesian direction, but isn't working on rotation scara.
How to make it working on rotation, but not working on move?
Tx
  • For each move you queue you can say if it should watch hardware nedstops.  I guess you have set this parameter to false when enqueuing it in your rotation function. It's normally the last value if I remember correctly.
  • Thx, problem solved
