Configuring Discount SmartLCD Controller
What is the procedure for configuring the discount smart lcd/sd card controller? I've looked everywhere and can't seem to find any relevant information. I'm using a ramps board by the way. Any help is appreciated.
  • In config tool you select the display type. For ramps it should then work out of the box. Just make sure to select the right one - graphic if you have 128x64 pixel display or the normal smartcontroller for 20x4 char display.
  • Okay. I can't seem to figure out what I'm doing wrong. It's not necessary to import any libraries?
  • No, all libraries are build in. Typical errors are:
    - wrong display selected
    - defect cable
    - cables in wrong connector or wrong rotated.
    - defect display
