Problem with printed objects
I've been printing some objects with support material around objects to prevent objects to collapse. The problem is that this "pillars" are printed too close to the object that are literally welded together, so when I try to remove the support material I end up destroying the object, here I'm attaching a coffee mug with its handle destroyed when I try to remove the support material, I've been playing around with the support material settings at the repetier host with the intention of separating or creating a little gap between the printed object and the support material but I haven't succeeded yet, wonder if someone has a clue of what am I trying to do. here's a picture
