Z-probe:NAN
Hello
Cartesian printer
z max,y max et x max Getech Mechanical End Stop V1.2
z mini et z probe IR Z Probe 1.4
17:35:43.880 : Printer reset detected - initalizing
17:35:43.880 : start
17:35:43.880 : Info:External Reset
17:35:43.880 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
17:35:43.880 : Free RAM:5045
17:35:43.882 : SelectExtruder:0
17:35:44.084 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3
17:35:44.084 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
17:35:44.084 : PrinterMode:FFF
17:35:44.084 : N10 M220 S100*80
17:35:44.084 : N11 M221 S100*80
17:35:44.084 : N12 M111 S6*84
17:35:44.084 : N13 T0*8
17:35:44.088 : X:0.00 Y:0.00 Z:0.000 E:0.0000
17:35:44.088 : DebugLevel:6
17:35:44.088 : SelectExtruder:0
17:35:44.090 : Unknown command:N7 M20
17:35:44.107 : DebugLevel:6
17:35:44.107 : SelectExtruder:0
17:35:45.141 : N14 G28*38
17:35:49.450 : X:274.00 Y:325.00 Z:218.000 E:0.0000
17:35:50.094 : N17 G1 X-50 F4800*36
17:35:51.033 : N21 G1 X-50 F4800*33
17:35:51.918 : N24 G1 Y-50 F4800*37
17:35:52.682 : N27 G1 Y-50 F4800*38
17:35:53.572 : N31 G1 Y-50 F4800*33
17:35:57.135 : N34 G30*45
17:36:56.073 : Z-probe:NAN X:174.00 Y:175.00
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 0
#define ENDSTOP_Y_BACK_ON_HOME 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 1
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 274
#define Y_MAX_LENGTH 325
#define Z_MAX_LENGTH 218
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 55
#define DISTORTION_YMIN 55
#define DISTORTION_XMAX 250
#define DISTORTION_YMAX 315
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 4
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 1.95
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 55
#define Z_PROBE_Y1 55
#define Z_PROBE_X2 55
#define Z_PROBE_Y2 250
#define Z_PROBE_X3 55
#define Z_PROBE_Y3 315
#define BED_LEVELING_METHOD 1
#define BED_MOTOR_1_X 55
#define BED_MOTOR_1_Y 55
#define BED_MOTOR_2_X 55
#define BED_MOTOR_2_Y 250
#define BED_MOTOR_3_X 55
#define BED_MOTOR_3_Y 315
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
