Extruder and hot end do not work correctly on ramps 1.4
Hello all,
I am a newbie on 3d printing, and electronics.
My Monoprice Select Makers V 2 (Wanhao i3 clone) has fatal problem, where its extruder capacitor blew up. I decided then to changed the whole motherboard to ramps. I found 2-in-1 sainsmart ramps board. I since installed the board on, until I tried to adjust the extruder motor.
The following are the problem that I have:
1. The hot end does not heat up, and it kept throwing heater decoupled error on the control board. I disabled the test on the firmware, the error disappeared, but the hot end is still not heat up. Out of the curiosity, I moved the wiring for extruder on the board, from ext0 to ext1. Hold and behold the extruder start to heat up. Is this correct? Btw I clone the ext1 port for my 2nd z axis . Since I have 2 z motor. The z axis works perfect.
2. The extruder motor does not work. It wired to ext0 port. I tried to adjust best, but it still does not feed the filament in. I can see the controller showed the filament moved, but not physically.
I am running out of idea on what should I do her, please I need help. Thank you.
  • Here is the firmware script for the extruder.
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 0
    #define XAXIS_STEPS_PER_MM 80
    #define YAXIS_STEPS_PER_MM 80
    #define ZAXIS_STEPS_PER_MM 400
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 105
    #define EXT0_TEMPSENSOR_TYPE 97
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 1
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_DECOUPLE_TEST_PERIOD 0 // changed from 12000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  2
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define NUM_TEMPS_USERTHERMISTOR0 0 // changed from 0
    #define NUM_TEMPS_USERTHERMISTOR1 0 // changed from 0
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 0
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    //#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000
    #define HEATED_BED_DECOUPLE_TEST_PERIOD 0
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
  • Not sure what the problem is. Configuration looks ok if you connected thermistor to T0 and extruder heater to D10.
    Extruder motor will only turn if extruder is hot or if you had send M302 S1 to allow cold extrusion.
    What I don't see is FEATURE_FAN_CONTROL so I assume you have no filament cooling fan. Otherwise D9 would be used by that by default overwriting a heater that wants to use that output.
  • Repetier,
    sorry for delay response.
    Since then, I have fixed the extruder motor issues. I made adjustment on the stepper drive by replacing the jumper pin. I also made couple adjustment to Z-drive movement on the firmware.
    I still trying to solve the mystery for the hotend heater issue. I will take a look on my wiring again.
    I was able to print again, but I have a problem on the first layer print.
    Initially, the print started on 0.3 mm for the first layer of print.
    I did not see anything printed. the extruder head just go round and around.
    Then I changed the first print layer to 0.5 mm, and it started printing.
    However, I notice it lack of adhesion between layer on the x-axis of the brim.
    The brim crumble out like a layer of spaghetti put together.
    The part that I print has an issue on the surface, it has rough finishing.
    My hypothesis at the moment is the bed is not level.
    Do you think it is reasonable assumption?
    Funny you pointed out that FEATURE_FAN_CONTROL is not available on the code that posted above. I have cooling fan, and I noticed it did not turn on, even the display shows the fan is on.
    Do I make a mistake in wiring?
    or should I post the FEATURE_FAN_CONTROL line on my firmware?
    Thank you for the guidance.
  • What display shows fan is on? On host or printer LCD? If it is printer lcd you have compiled it and D9 is the output normally. Host will not know if you have a fan and only looks if you have send the command, so that does not count.
    If extruder is too close to bed it will not extruder only try. If distance is too high it will not stick (also if bed condition is wrong it will not stick as well). At the beginning of skirt it will also not stick as it takes a bit of extrusion to get it going good.
    If parts stick and others don't it normally the bed that has different distances so rotation is bed. Hard to say remotely what problems match your case.
  • Repetier,
    After several hours trial and error, I figure out the problem with the cooling fan. The Feature_Fan_control is on the firmware, already.
    I notice, 2-in-1 Sainsmart board has the pin arrangement slightly different than typical ramps board.
    The fan is now working, as I wire it to extruder 0 port, recall the hotend does not heat up initially when it connected to extruder 0 port, but work when I connect to extruder 1 port.
    I was able to print a thin part, after I level the the printer bed. However, as I try to print a thicker part, i.e.: 10 mm part, it started okay, but as it goes to 2 to 3 mm higher, the printing result start to shift.
    I tried to print at slower speed, through slowing down speed in slicing configuration. I use Repetier host and Cura Slicer. I reduce the speed to half and increase the infill configuration, but I still receive the same misalignment/ shifted layer as a result.
    Now I suspect that either the extruder motor speed, either is too fast and/ or the z-axis movement is slower than the x-y movement.
    Is there anyway that I can control the printing speed for z and. or extruder from the firmware?
    Thank you, and sorry for all these long winded questions.
  • First you could set ALWAYS_CHECK_ENDSTOPS 0 which disables endstop testing. If endstops trigger from crosstalk to motors/heaters your print shifts away from endstop over height. That is a well known issue many have. If that is the case try twisting your endstop and motor cables (should be anyway) to reduce crosstalk.
    Other reasons might be jerk too high or acceleration too high. In these cases shifts are more random.
  • Departure, thank you for the walk through for all the issues. At this point all of the issues have been resolved. Here are the steps that I did to resolve the problem:
    1. For the shifted layer, I was able to fix it by updating the arduino program to the latest version, I think 1.6. I believe there is something in arduino compiler that did not translate correctly when it uploaded to the machine.
    2. I added more stabilizer on the base of the printing base, I.e. put some shim on the bottom of the table.
    3. I reduce the printing speed to 75% manually. This help with the quality of the printing.
    4. I made adjustment to the steps per mm for all the motor, based on some suggestion from YouTube channel. Very simple process, but it takes time to do so.
    If I would like to reduce the speed and acceleration of the motors in the firmware, which line of code should I adjust?
    Once again, I am grateful for the help.
  • I disable ALWAYS_CHECK_ENDSTOPS and it seems the printing is better now.
    Is there any problem in the future, when this function disable?
  • The only drawback is that without ALWAYS_CHECK_ENDSTOPS  you will not detect if you lost steps so head goes outside print area. But since that causes exactly this to happen I see no disadvantage. We test area in addition anyway (al least in dev).
  • edited October 2016
    Repetier, I thought I fix the issue, but it still persist. Now it is in printing small object. I noticed that the movement snag in some occasion while printing.
    Is this mean the machine jerking?
    Afterward, I noticed the printing start to shift between layer.
    I believe this is still a crosstalk problem, is it true?
    Btw I try to understand the crosstalk.
    How do you fix it?
    Do I need to bundle a motor cable with the end stopper cable, I.e.: y motor with y end stop, etc.?
    I read from some other group, it mentioned about wrapping the cable with aluminium foil.
    Does it make any sense wrapping the cable with aluminium foil?
    Thank you.
  • here is the configuration.h
       as you expect.
    #include "pins.h"
    #define M302 S0
    #define XAXIS_STEPS_PER_MM  160//160 per calculation 80 per wanhao
    #define YAXIS_STEPS_PER_MM 160//160 per calculation 80 per wanhao
    #define ZAXIS_STEPS_PER_MM 800//800 per calculation, was 100, 400 per Wanhao
    #define EXTRUDER_FAN_COOL_TEMP 100
    #define EXT0_STEPS_PER_MM 215 // 381 per calculation, Extruder speed controller 105 per Wanhao, 140 works OK
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MAX_FEEDRATE 35 //50 original
    #define EXT0_MAX_ACCELERATION 30//5000
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_PID_INTEGRAL_DRIVE_MAX 200
    //#define SKIP_M109_IF_WITHIN 2
    #define SKIP_M109
    #define EXTRUDE_MAXLENGTH 200
    #define HAVE_HEATED_BED 1
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 1
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 180
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 100 //100 initial
    #define MAX_FEEDRATE_Y 100 //100
    #define MAX_FEEDRATE_Z 2
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 2
    #define HOMING_ORDER HOME_ORDER_XYZ
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 1
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 375 //1000 original
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 375
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 // changed from 100
    #define MAX_JERK 3 //20
    #define MAX_ZJERK 0.2
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define FEATURE_TWO_ZSTEPPER 1
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 0
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 0
    #define Z_PROBE_PIN -1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 40
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 20
    #define Z_PROBE_Y1 20
    #define Z_PROBE_X2 160
    #define Z_PROBE_Y2 20
    #define Z_PROBE_X3 100
    #define Z_PROBE_Y3 160
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Mod_I3"
    #define UI_PRINTER_COMPANY "Victor"
    #define UI_ANIMATION 0
    #define UI_DISABLE_AUTO_PAGESWITCH 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   170
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   245
    #define UI_SET_MIN_HEATED_BED_TEMP  30
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define UI_SET_EXTRUDER_FEEDRATE 25
    #define NUM_MOTOR_DRIVERS 0
  • Crosstalk is caused by electromagnetic field from motor/heater cables. Simple solution is to twist these cables so fields change direction and effects even out. Foil around motor/heater cables shields better for the field.
  • Repetier, I am running out of idea. I have tied all the end stopand motor cables, shieled it with aluminum foil and cover it with electrical tape. The problem is still persist. Is there anything that I can do at this point? Thank you.
  • Do you cool your stepper drivers? If the get too hot motors do strange things as well.
  • I put a heat sinks on the top of the chip. Should I put a cooling fan too?
  • It depends on current set on drivers. If you go near limit a extra cooler is helpfull with decent currecnt passive cooling also works. Just test temperature of heat sinks.
  • Repetier,
    I noticed that the first 5-minute of printing is fine, no shifting.
    As the printing time progress, I start noticing more layer printing shift.
    I have five drivers on all the board, and all of them have a passive heat sink mounted on the top of it.
    Since to mention about the current set on drivers, I could not get the good reading on these driver. I meant the voltage reading on the these drivers does not match with the instruction that I found online.
    I used DRV8825, and what I can tell I am running about 2x voltage than my calculated voltage value. If I reduce it to 1.5x, the motor would not move. I purchase 2 sets of these drivers, and there are no difference in voltage reading.
    Did I do something wrong here?
    Thank you for your help.
  • I can't advice on hardware - not my field. But as it works first 5 minutes it might really be a temperature issue. So add a fan pointing on drivers - that cools much more then passive, so the state from first 5 minutes should hold the whole print.
  • Repetier,
    I convinced now that the problem is in current that regulated to these drivers. I have some A4988 drivers lying around with heat sink installed on the top of the chip. I installed it on the x-axis, and I saw the print shifted after every 2 rounds (I have built a square print object as a test). The shifts are not on the following layer, but on the x-axis.
    I will try to install a fan pointing on the top of these drivers.
    Also, I am going to try to increase the step size on the z-drivers to 1/16, as I think it does not need 1/32 stepper and I can lower the z-axis step per mm on the firmware.
    I understand that you mentioned about you can't give an advice on the hardware, but have you ever come across the problem with the board that cause the layer to shift?
    Is it possible that the current regulator on the board not functioning correctly?
  • Only board I know that have/had problems was rumba board, where Y step line crossed other line on board too close, so it sometimes got a wrong step from interference.
    Current on board is ok I think or you would get firmware crashes, connection problems ...
    Most professional printers cool the drivers for a good reason I guess.
  • That's it. I looked at rumba board, and my board has similar layout, where the other z axis stepper board is on the other way of the board.my printer is using 2 z motors. It has to cross y axis port. Originally, the printer is using Melzi, where the z ports are sitting side by side.
    I am curious, How do other users getting over the problem on rumba?
    I thought about connecting the z axis motor in series to a stepper drive, but I against it due to potential overheating on the driver.
    I will e interesting to learn about the solution.
    Thank you.
  • On rumba you simply connect y motor to E1 socket. You could use Y socket as E1 instead. For extruder the lost step is real issue.
  • Repetier,
    Since the last discussion, I decided to change the board back to Melzi at the moment. I still have the RAMPS board for a future upgrade.
    In regard to lost e step, I noticed that one of my leadscrew is bowing or no longer straight. I am in the process of replacing the leadscrew. I have experienced lost e-step in certain print height.
    Thank you for your help and support.
