Z-Probe on Delta (Hexagon V2) wrong Z-High after Probing
i want to enable Z-Probing in Repetier 0.92.8
I have installed x,y,z max Switches for Homing. It works well.
If i use G32 to probe the bed everything is fine, i get three points. But after that, my Zmax hight isn't correct.
Z_PROBE_BED DISTANCE 10
After G32 the Log says Printer hight is 445.82, but it is about 24.4 mm too much.
Where is my mistake?
Regards Christian
  • i must add some Informations:
    I use an Z-Probing with FSR Sensors. So i have no Distance between Nozzle an Sensor.
  • sorry, my Firmware Version is the actual Version 0.92.9
    Is it helpful to use the dev Version?
  • This error might come from bed coating or z probe height. Coating should be zero and z probe height 0 or a small negative value if bed bends until triggering force is reached. These determine z height after probing.
  • Hello,
    please have a look at my configuration.h
    An here is the log from my calibration. I do the same steps as in your video shown.
    < 07:19:56: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
    < 07:19:56: Printed filament:135.63m Printing time:1 days 17 hours 57 min
    < 07:19:56: PrinterMode:FFF
    < 07:19:56: DebugLevel:6
    < 07:19:58: Info:Autoleveling disabled
    < 07:19:59: SelectExtruder:0
    < 07:19:59: X:0.00 Y:0.00 Z:445.800 E:0.0000
    < 07:19:59: Info:Autoleveling enabled
    < 07:24:11: Info:Autoleveling disabled
    < 07:24:12: Tower 1:160
    < 07:24:12: Tower 2:161
    < 07:24:12: Tower 3:0
    < 07:24:13: SelectExtruder:0
    < 07:24:13: X:0.00 Y:0.00 Z:445.800 E:0.0000
    < 07:24:59: Z-probe state:L
    < 07:25:08: Z-probe state:L
    < 07:25:16: Z-probe:34.43 X:0.00 Y:0.00
    < 07:25:28: SelectExtruder:0
    < 07:25:28: X:0.00 Y:0.00 Z:445.800 E:0.0000
    < 07:25:59: SelectExtruder:0
    < 07:25:59: X:0.00 Y:0.00 Z:445.800 E:0.0000
    < 07:26:03: Z-probe:34.39 X:20.00 Y:20.00
    < 07:26:08: Z-probe:34.63 X:90.00 Y:20.00
    < 07:26:13: Z-probe:34.50 X:-20.00 Y:-90.00
    < 07:26:15: plane: a = 0.0035 b = -0.0023 c = 34.3631
    < 07:26:15: Transformation matrix: 0.999994 0.000000 -0.003529 0.000008 0.999997 0.002304 0.003529 -0.002304 0.999991
    < 07:26:15: CurrentZ:34.50 atZ:35.00
    < 07:26:15: Z after rotation:35.00
    < 07:26:15: Printer height:445.30
    < 07:26:15: Info:Autoleveling enabled
    < 07:26:15: X:-20.12 Y:-89.92 Z:34.636 E:0.0000
    < 07:26:15: Info:Autoleveling disabled
    < 07:26:19: SelectExtruder:0
    < 07:26:19: X:0.00 Y:0.00 Z:445.300 E:0.0000
    < 07:26:19: Info:Autoleveling enabled
    The Problem after G32 S2 is, the printer high. It is too high, so every following command fails with a damage in the bed.
    Regards Christian
  • Z_PROBE_BED_DISTANCE 0
    should be 5mm or so. It's how much it goes up. You z probe height is set 0.1 and should be 0.
    That said, check which values are in eeprom that get really used. I think there you have different values.
  • Hello,
    ok many thanks, now i get it run. auto leveling is now korrekt. There was a wrong value in the eeprom for Z_Probe_High.
    Next step is Distortion_Correction in your Video.
    G29 measure only three points and give a average height. In the video it measure more Points, In configuration.h ist the Value 5
    My configuration.h is now this one.
    Many thanks for the support.
    Regards
    Christian
  • G29 is now G33
    and you have not compiled distortion correction, see
    #define DISTORTION_EXTRAPOLATE_CORNERS 1
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
