Probing points problem
Hello, I'm using  Reptetier 0.92.9 and i'm setting up auto-leveling on my kossel mini, but when i reach the part of send the G33 command the effector lowers and start moving to a position outside the bed.
Sending the G33 L0 command gives me probing points different from my set up, wich is the 3 point method with the location of them stored on eeprom.
If I run the height map tool on repetier software the printer probes the bed like it was supose to.
Any idea how can I fix this?
Thank you in advance!
Afonso Muralha
  • G33 has it's own configuration of points to probe defined in config tool/configuration.h. So update the area there and reupload.
