Can't compile firmware
I am having problems with compiling firmware i've made in configuration tool for 0.92 firmware. It keeps indentifying errors in it. I've tried all versions of Arduino IDE and tried to do the same firmware in configuration tool 0,91, with no result. Only once it came to uploading, but now i need to get repaired version of firmware to the board (MEGA 2560 with RAMPS 1.4 - with instaled right driver). Everytime it¨s nearly same error message.
Arduino: 1.6.5 (Windows 8.1), Vývojová deska: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from HAL.h:83:0,
                 from Repetier.h:539,
                 from HAL.cpp:1:
HAL.cpp: In function 'void __vector_22()':
fastio.h:29: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
 #define  _WRITE(IO, v)   do { if (v) {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ##  IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
fastio.h:48:25: note: in expansion of macro '_WRITE'
 #define  WRITE(IO, v)   _WRITE(IO, v)
HAL.cpp:847:91: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_BOARD_FAN] = (pwm_pos[PWM_BOARD_FAN] & COOLER_PWM_MASK)) > 0) WRITE(FAN_BOARD_PIN,1);
fastio.h:29: error: 'DIOORIG_FAN2_PIN_PIN' was not declared in this scope
fastio.h:17:30: note: in definition of macro 'MASK'
  #define  MASK(PIN)    (1 << PIN)
HAL.cpp:850:81: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_FAN1] = (pwm_pos[PWM_FAN1] & COOLER_PWM_MASK)) > 0) WRITE(FAN_PIN,1);
HAL.cpp:947:108: note: in expansion of macro 'WRITE'
     if(pwm_pos_set[PWM_BOARD_FAN] == pwm_count_cooler && pwm_pos_set[NUM_EXTRUDER + 1] != COOLER_PWM_MASK) WRITE(FAN_BOARD_PIN,0);
  • You are using ORIG_FAN2_PIN in your configuration but apparently your boards pin definition does not define that pin. In that case check board description and use the digital pin number instead for that function.
