Application crashed
Hello dear saviors.
I have problem with Repetier-server app on Win7-x32(Intel C2D E6500, 2Gb Ram,500Gb Hdd).
1st problem: When I upload .stl to the server via web, interface change temperature of bed. I think that it's default(50 C) and add predefined bed temp. But after that interface still change bed T to 50.
2nd problem: App crashed after some time, this system log:
- <System>
  <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
  <EventID
Qualifiers="49152">7034</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>0</Task>
  <Opcode>0</Opcode>
  <Keywords>0x8080000000000000</Keywords>
  <TimeCreated SystemTime="2016-08-12T13:22:06.877187400Z" />
  <EventRecordID>3312</EventRecordID>
  <Correlation />
  <Execution ProcessID="500" ThreadID="3172" />
  <Channel>System</Channel>
  <Computer>orca-serv</Computer>
  <Security />
  </System>
- <EventData>
  <Data Name="param1">RepetierServer</Data>
  <Data Name="param2">2</Data>
  </EventData>
  </Event>
  • Do you really mean uploading stl and not gcode? Uploading gcode is not supported. Does the crash happen when you upload stl files?
    I also see not what you the connection between uploading a stl and bed temperature is. Uploading should not change any temperatures. Running gcodes set temp. on what is defined in gcode normally so it can override your start temperature.
