Control RGB LED strip (common anode)
I am trying to connect a RGB LED strip(Common anode) to my printer (RAMPS 1.4). Is there a build in feature in Repetier?
  • No, you need a own solution using the event system for this. See on github there is a event system implementation for this for I think it was a adafruit rgb light. Take that and adjust how to set colors for your system. These files are copied into the main source.
