Repetier-host-1.6.2 to Marlin-1.0.0 issues
I have some difficulties interfacing those two software.
Apparently, they both attempt to transmit the moment connection is established. This transition seems to defect the arduino-marlin in a bad way.
In an attempt to cope with it, I set the handshaking "Use Ping-Pong communication (Send only after ok)".
It somehow smooth the problem.
However the marlin report: "echo: SD card: ok". The repetier-host sees this ok as handshaking. :-(
And I still suspect that my serial port communication is not set properly and this cause some serial port exception.
So:
a. Can we have repetier-host to slow down for a few second while marlin makes it "speech"?
b. Can you treat "ok" as handshaking when it comes after newline?
c. Can you publicize the serial port parameters of the repetir-host?
Thank you!
Michael
Log file follows:
21:43:21.889 : OpenGL version:4.0.0 - Build 10.18.10.4176
21:43:21.889 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
21:43:21.889 : OpenGL renderer:Intel(R) HD Graphics 4000
21:43:21.889 : Using fast VBOs for rendering is possible
22:08:50.444 : No start signal detected - forcing start
22:08:52.794 : Printer reset detected - initalizing
22:08:52.814 : start
22:08:52.814 : echo: External Reset
22:08:52.814 : Marlin1.0.0
22:08:52.814 : echo: Last Updated: Mar  2 2016 13:59:36 | Author: (none, default config)
22:08:52.814 : Compiled: Mar  2 2016
22:08:52.814 : echo: Free Memory: 11889  PlannerBufferBytes: 1232
22:08:52.814 : echo:Stored settings retrieved
22:08:53.084 : echo:SD card ok
22:08:53.094 : Error:Line Number is not Last Line Number+1, Last Line: 1
22:08:53.094 : Resend: 2
22:08:53.154 : Error:Line Number is not Last Line Number+1, Last Line: 2
22:08:53.154 : Resend: 3
22:08:53.184 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
22:08:53.204 : Error:Line Number is not Last Line Number+1, Last Line: 3
22:08:53.204 : Resend: 4
22:08:53.234 : echo:Active Extruder: 0
22:08:53.254 : Begin file list
22:08:53.254 : /P802MA~1.04/P802_4~1.GCO
22:08:53.284 : /P802MA~1.04/P802_A~1.GCO
22:08:53.284 : /P802MA~1.04/P802_L~1.GCO
22:08:53.284 : /P802MA~1.04/MIK5.GCO
22:08:53.284 : /P802MA~1.04/TUBE~1.GCO
22:08:53.284 : /P802MA~1.04/VALVET~1.GCO
22:08:53.284 : End file list
22:08:53.334 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:P802MA_8 EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
22:08:53.364 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
22:08:53.394 : echo:Active Extruder: 0
22:08:53.414 : Begin file list
22:08:53.414 : /P802MA~1.04/P802_4~1.GCO
22:08:53.444 : /P802MA~1.04/P802_A~1.GCO
22:08:53.444 : /P802MA~1.04/P802_L~1.GCO
22:08:53.444 : /P802MA~1.04/MIK5.GCO
22:08:53.444 : /P802MA~1.04/TUBE~1.GCO
22:08:53.444 : /P802MA~1.04/VALVET~1.GCO
22:08:53.444 : End file list
22:08:53.484 : Begin file list
22:08:53.484 : /P802MA~1.04/P802_4~1.GCO
22:08:53.514 : /P802MA~1.04/P802_A~1.GCO
22:08:53.514 : /P802MA~1.04/P802_L~1.GCO
22:08:53.514 : /P802MA~1.04/MIK5.GCO
22:08:53.514 : /P802MA~1.04/TUBE~1.GCO
22:08:53.514 : /P802MA~1.04/VALVET~1.GCO
22:08:53.514 : End file list
22:08:53.584 : echo:Active Extruder: 0
  • Actually the ok is checked like this:
    res.StartsWith("ok")
    meaning line starts with ok. If you enable logging commands it would maybe more easy to see what is exactly happening. I will also try with my marlin also it is 1.1RC.
    My guess is more
    causes the problem. Firmware sends "start" quite early, so we do not have to wait too long for it to appear after connect. As you see the timeout was reached and host normally then sends also some lines and my guess is that these interfere. Can you say how long it takes between connect button and start to appear?
    Does connection normalize after the start problem?
