SmartRamps + AZSMZ display
Hi guys.
I received my AZSMZ display that can be used with the smart ramps and the due, but the firmware 0.91 is freezing, not start up correctly, prints are problematic, etc...
The display:
The firmware:
http://reprap.org/mediawiki/images/0/02/SMART_RAMPS_RepetierDue_En.zip     (need modify the byte for non inverted chars 0x0c0 ).
There are any way to migrate this display on firmware 0.91 to 0.92.9 ?
Anyone that knows due can help me?
  • If the display works on 0.91 it should work with 0.92 as well. Using the online config tool would upgrade config file if old one was also made with config tool. That is the main reason for the config tool.
  • edited March 2018
    I had the same problem. AZSMZ LCD support was added to Repetier 1.0 and dev version, but here is modified file to work with AZSMZ 12864 LCD display with the Smart RAMPS on Repetier 0.92.9.
    1. Configure in your Repetier firmware: Display Controller >> Manual definition of display...
    2. Unzip and copy uiconfig.h file into firmware folder.
    3. Run Android IDE and flash the firmware.
    PS: for some reson I cannot add a file to the post. So here is link for it https://drive.google.com/open?id=1r2RYOWUwLUEn4VXlZ-vOnkxAXl7InTFp
