v0.92 problem with G1 and x-axis
I have a self-made prusa with steep-threaded spindles in x-y.
http://www.thingiverse.com/thing:1598584
Electronic:
Radds 1.5 with Raps128, 6 endstops, capacitive sensor.
The commands G1/G29/G32 are moving my x-axis in a not normal way.
Repetier Host and Server shows me that the x-axis hasn't been moved, but the x-axis has been moved for nearly 30mm.
Prior I had some some commands in the "before/after" printjob scripts like G1 Z5 X15 oder G1 Z160 X0
While the z-axis moves, the x-axis is slowly moving.
When the z-axis goes down, the x-axis goes slowly into +. When the z-axis finishes, the x-axis moves 15mm, too. G1 Z5 X15 positions Z5 X45
But I'm more in trouble, when the z-axis moves up.
Then the x-axis crashes very slowly into the x-min endstop and doesn't stop. It ist very loud then!
G29.
First G28. All move right. (x/y -1/ z 1)
Then G29.
The z-axis moves down (x- doesn't move)
The x-y-e move normally für measuring
The z-axis goes up
The z-axis goes down, the x-axis is moving slowly into + (the shown x positions at host/server are not the same like the physical one)
Same with G32
The z-axis goes up
#define NUM_EXTRUDER 2
#define MOTHERBOARD 402
#define RFSERIAL SerialUSB
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN -1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 0
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 1007.874015748
#define YAXIS_STEPS_PER_MM 1007.874015748
#define ZAXIS_STEPS_PER_MM 17066.666666667
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 33260
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 740.79391693682
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 45
#define EXT0_MAX_START_FEEDRATE 15
#define EXT0_MAX_ACCELERATION 4000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 0
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 740.79391693682
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 1
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 45
#define EXT1_MAX_START_FEEDRATE 15
#define EXT1_MAX_ACCELERATION 4000
#define EXT1_HEAT_MANAGER 3
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 45
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_SPEED 25
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 0
#define PID_CONTROL_RANGE 15
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 170
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 1
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 150
#define SKIP_M190_IF_WITHIN 1
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 175
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 30
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   10
#define HEATED_BED_PID_IGAIN   0.023
#define HEATED_BED_PID_DGAIN 305.4
#define HEATED_BED_PID_MAX 175
#define HEATED_BED_DECOUPLE_TEST_PERIOD 30000
#define MIN_EXTRUDER_TEMP 170
#define MAXTEMP 275
// ##                             Laser configuration                                      ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 5
#define ENDSTOP_Z_BACK_ON_HOME 1
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 1
#define DISABLE_Y 1
#define DISABLE_Z 1
#define DISABLE_E 1
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 145
#define Y_MAX_LENGTH 245
#define Z_MAX_LENGTH 160
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION_POINTS 3
#define DISTORTION_START_DEGRADE 12
#define DISTORTION_END_HEIGHT 15
#define DISTORTION_XMIN 0
#define DISTORTION_YMIN 65
#define DISTORTION_XMAX 105
#define DISTORTION_YMAX 230
// ##                           Movement settings                                          ##
#define BABYSTEP_MULTIPLICATOR 128
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 500
#define MAX_FEEDRATE_Y 500
#define MAX_FEEDRATE_Z 5
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 3
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 2
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 80000
#define ALLOW_QUADSTEPPING 0
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 4000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 4000
#define MAX_JERK 15
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define ENABLE_QUADRATIC_ADVANCE 1
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PIN 37
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 75
#define Z_PROBE_Y_OFFSET 20
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 3
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_HEIGHT 2.3
#define Z_PROBE_FINISHED_SCRIPT "G1 Z10 F1500\nG1 X15 Y230\nG1 Z1.5\nG1 Z10"
#define Z_PROBE_REQUIRES_HEATING 1
#define Z_PROBE_MIN_TEMPERATURE 120
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 0
#define Z_PROBE_Y1 65
#define Z_PROBE_X2 95
#define Z_PROBE_Y2 65
#define Z_PROBE_X3 0
#define Z_PROBE_Y3 225
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 1
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 0
#define FEATURE_CONTROLLER 0
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 1
#define LANGUAGE_ES_ACTIVE 1
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 1
#define LANGUAGE_TR_ACTIVE 1
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define NUM_MOTOR_DRIVERS 0
#endif
