Z axis Doesn't Stop When Endstop Triggered
My Z axis moves in the correct directions using manual control. If it's moving up (away from the bed and away from the endstop) I can trigger the endstop with my finger and it will stop. If I home the z axis (down towards the bed and endstop) it just keeps going crashing into the bed.
Here is my configuration.h:
// ################ Endstop configuration
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_Z_MAX_INVERTING true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 180
#define Y_MAX_LENGTH 180
#define Z_MAX_LENGTH 120
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
M119 shows: endstops hit: x_min:L  y_min:L  z_min:L   When I trigger the z endstop  z_min changes to H
My printer is a reprap Prusa Mendel i2. Mega 2560 with RAMPS 1.4. Computer is running Win 8.1. Latest Repetier firmware and host 1.6.1.
How can I get the z axis to stop when it hits the endstop?
  • You z home dir is wrong, must be -1 for z min homing. Since you assume this was right I guess you also need to invert z direction.
