Eeprom parameters change
I'm new in this and have a question
How can we change the parameters in eeprom ?
My Z axis is running 2mm instead of 10mm ordered.
  • Connect using Repetier-Host or Server. They have a function to edit eeprom values once you are connected.
  • Thanks for the prompt answer.
    I followed your advice and solved the problem!
    Thank you
