"SD Card" Tab
I just downloaded and installed Repetier-Host V1.0.6. This version has a tab labeled "SD Card" in the right menu, along with "Object Placement," "Slicer," etc. Now, my printer does not have an SD card, so I unchecked the "Printer has SD Card" box in the printer settings menu. The "SD Card" tab subsequently disappeared, as it should, because I couldn't do anything with it. However, when I restarted Repetier-Host, the tab reappears. It only disappears after I open and then close the printer settings menu, even though my printer without the SD card is listed as default. Is there any way to keep this tab closed even through restarts of the program?
