can't print without support
even if i uncheck the support option in slicer he will generate support... thats pretty frustrating. has someone had thit problem before?
  • Check if you have override settings enabled. Then host has it's own support flag that overrides what you set in slic3r. If disabled it is important what you set in slic3r.
