load 3d object file but won't print
I have a problem with repetier, I can load a 3d object file and I see it drop into the display positioning box but I see no g-code loading for it at all? I have another 3d file that is too big for my printer but it loads the g-code even though it won't print it. I can move all parts of the printer manually just fine but when I click print job it does not actually do anything and print status says no job defined? My extruder and bed both heat up fine as well. should I re-install? It worked fine for a couple of prints but now it won't start.
