Raspberry pi 3 - Repetier-server keeps running
I have tried to install the latest version of repetier-server for my raspberry pi, but when I install it, it keeps Running and nothing happens.
Is the version still not compatible with the raspberry pi 3?
THanks in advance!
  • edited April 2016
    SOLUTION:
    Do this in the terminal
    sudo dpkg -i repetier_armel.deb
    You can see the status, if you just install it like the picture above, it keeps running. It's a glitch I think, because it is installed!
  • I think the sudo makes the difference as youmust be root to install package.
    How did you do it on the desktop?
