Radds LCD goes Blank after longer printting time
Hi I am using an Radds LCD. after a while of rinting via usb my display goes blank and does not wake up again. what could be wrong?
after reset everything fine again.
PHilipp
    Might be a communication failure with the display making it not understand send commands any more.
    Try adding
    #define TRY_AUTOREPAIR_LCD_ERRORS
    in manual tab. Reinitalizes display every second and might help.
    Seems like it did the job... 3hours into the print and LCD is on!
    I've experienced the same issue on my newer radds 1.5 and lcd recently purchased from reprap.me. I don't think my other older radds board (1.1?) and lcd has had this issue.  I am running the latest version of the firmware from github.  I wouldn't mind having an auto repair that runs less frequently like every minute as the flashes from the resets every second can get annoying.
