Connection quirk
edited September 2014 in Questions & Answers
When I connect RH (1.0.2) to my Printrbot Metal Simple it seems to connect but none of the manual controls will work until I first go to the manual control page and click OK in the Debug Options section.  Before I do that each command I issue, say Home X, will queue up and the top bar will read 7 Commands Waiting...  8 Commands waiting etc.
Clicking the OK in the Debug Options seems to solve the problem and I can use the printer and all of the RH features just fine after that but this does not seem normal.  Does this indicatate, perhaps, a config problem on my part?  This happens with 0.95F as well as 1.02.
Rob
pic of my PH printer comm settings: www.dropbox.com/s/dxkir8besvpuime/PH.png?dl=0
  • I guess you have a printrboard included? These boards do not support reset on connect, so you need to disable that option. This changes a bit the expected starting behaviour.
  • Thanks. Setting Reset on Connect to Disabled fixed this problem!
