where is the support structure?
does support structure show in the model preview after slicing?
I have generate support checked in the config.
I went to verify it but if it generated it, it is not visible in the sliced model.
I have a 40x15x2 mm overhang so I am sure it needs it.
  • Yes, the preview does not know what is sopprt or not, so you will see it if generated.
    Depending on slicer it only generated support if it exceeds a certain size or angle and can not be solved by bridging. Also cura for example can set support everywhere or only if support would touch bed.
