Repetier Server - Unattended Install
Hi, I would like to know if it's possible to run an unattended install of repetier server, that is, no GUI shown up. Are there any command line parameters I can use to achieve this with the setup?
Also, where is the ApiKey stored in the computer so I can read it to use the API?
Thank you!
  • We use standard installer for each os. pkgbuild for mac, deb for Linux and NSIS for windows. No speacial things programmed so default options should work.
    Keys are stored in keys.sql but user should enter the key in other programms to use it.
  • Thank you very much! I couldn't any option in NSIS for unattended install but copying all the files from an installed Repetier-Server and creating the service manually worked perfectly!
  • Nullsoft silent install is /S /NCRC which is at least how we do it for the update install.
