Green Status Popup prevents clicks
When I save my printer settings, or delete a file, there is a green status update in the top right corner. While this is on the screen I can't click anywhere else.
I got used to waiting for it after saving printer settings, but when deleting gcode files from the server it really slows down the process of deleting lots of files, having to wait for the status to fade every time... :)
  • You are partially right. The flash messages create a box with flash width over whole height. So everything in that range is not clickable. Make it wider and you have no problems (which is why I never registered it).
    For next release I have set height to auto and also position to bottom where it does not disturb any more. Then only the message itself is not clickable, resp. message disappears on click.
