Extruders swapped
I recently flashed my Da Vinci 2.0A with repetier alls good except the extruders are reversed< left extruder is 1 and right extruder is 2 this should be the other way around any help with this issue would be much apresiated
  • Just swap definition for extruders if you do not like that order, also this is the normal for me.
  • how and or where do I swap the definitions?
  • In configuration.h all entries with EXT0 get EXT1 and EXT1 gets EXT0.
  • ok tried that but it didn't change a thing?
  • ok it changed the left extruder to the right extruder and vice versa but the left extruder still reads as extruder 1 and the right extruder as extruder 2, which is what I am actully trying to change. I need left to read as 2 and right to read as 1
  • ext0 is extruder 0 and ext1 is extruder 1. They have offsets defined to tell the position relative to a virtual origin. That is the only thing I can image you then mean as you already switched extruders which mean ext 0 became 1.
  • cheers have it all sorted now
