STL-Tweaker
edited March 2016 in Feature Requests
Hi makers & designers!
I'm working on a project to fully integrate 3D-Printing into the manufacturing process. This tasks requires a reliable auto-rotate module which positions the objects on the build plate in their optimal orientation.
For this purpose, I wrote the STL-Tweaker, available as open-source from Github.
This 3D object positioning tool, written in python, is also intended to be used as module. So feel free to integrate the STL-Tweaker into Repetier, your own Software or invoke it from the command line.
Here you can see a prototype with its tweaked clone.
Check out the STL-Tweakers Blogpost for detailed informations and the direct comparison between the STL-Tweaker and the StrataSys' CatalystEX auto-rotate function. You will be amazed!
I'm glad to hear about your applications!
Chris
