dual extruder and Repetier-Firmware configuration tool for version 0.92.8
edited February 2016 in Repetier-Firmware
hello
dual extruder and Repetier-Firmware configuration tool for version 0.92.8 you can not run a second heater (Heater pin: 2 heater normally used for extruder 1)
Hardware:
ramps 1.4 and LCD2004
can someone have a similar problem?
version of 07/12/2015 everything works
  • RAMPS + Heater for extruder 2 can collide with fan which uses the same pin. Make sure fan uses a different pin or disable fan usage.
  • hello,
    how i make sure that the fan use a different pin or how i could disable the fan usage?
    best regards
  • i had set in the configuration.h the line "
    //#define FAN_PIN   4  // Extruder 2 uses the default fan output, so move to an other pin"
    as"
    could you please help?
    best regards
