Motors Turn Off After G28
something strange  appears with the latest fw 0.92.8. After homing/G28 the motors of my delta a switching off.
Any idea how to solve? Thanx.
  • There is a timeout to disable motors. Normally 5 minutes. Please check timing in eepromif it is set too low?
  • I have noticed that already and did not change the behavior. Changed to various values - no operation.
    Any other ideas?
  • What does the log say? Is there any hint? Homing on delta does some error checking and exists on wrong homing. Maybe that causes the disable. Also do normal moves also cause motors to turn off afterwards?
  • Hi there,
    the log did not show anything unusual. I just flashed the firmware of as downloaded today and replaced my working configuration.h in the firmware before flashing. Then reloaded a working eeprom backup in repetier host.
    Everything is working fine so far.
    Thank you.
