0.92.8 G31 state don't change
I have problem with Z-probing in 0.92.8. With 0.92.3 version everything is ok. I have proximity sensor NPN NC plugged to z min pin.
This is my code:
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define Z_PROBE_BED_DISTANCE 15
#define Z_PROBE_PIN 18
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET -36
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 10
#define Z_PROBE_Y1 10
#define Z_PROBE_X2 180
#define Z_PROBE_Y2 10
#define Z_PROBE_X3 10
#define Z_PROBE_Y3 140
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
When I start G31 I have L state which is good but when I close something to sensor and start G31 again state don't change - is low too (led sensor change's of course).
I try everything. When I install 0.92.3 version it's working good so it's not a hardware issue.
  • Does M119 return the same problem?
    Is any function using pin 18 as well so we might have a conflict about the usage?
    I'm still using the z probe and it still changes signals, so I guess something in config may cause a conflict or pin 18 is wrong?
  • edited January 2016
    Thanks for replay. I have ramps 1.4. Sensor is connected to endstop Z-min S pin (I think that is a pin 18). I don't think that confilct is a problem. I searched configuration.h for 18 and nothing found. I tryed to use:
    #define Z_PROBE_PIN ORIG_Z_MIN_PIN
    #define Z_PROBE_PIN Z_MIN_PIN
    My code:
    along with Repetier-Firmware. If not, see .
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    generator: http://www.repetier.com/firmware/v092/
    as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define FAN_THERMO_PIN -1
    // Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
    // If it is incompatible you will get compiler errors about write functions not beeing compatible!
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL -1
    #define BLUETOOTH_BAUD 115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 160
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 80
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 98.15
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 6.39
    #define EXT0_PID_I 0.24
    #define EXT0_PID_D 41.66
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 0.6
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_REHOME 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 8
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ## Laser configuration ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ## CNC configuration ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 195
    #define Y_MAX_LENGTH 185
    #define Z_MAX_LENGTH 160
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 180
    #define DISTORTION_YMAX 180
    // ## Movement settings ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 20
    #define HOMING_FEEDRATE_X 20
    #define HOMING_FEEDRATE_Y 20
    #define HOMING_FEEDRATE_Z 5
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 500
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 500
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P S / ServoID = 0..3 pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS -1
    #define SERVO1_NEUTRAL_POS -1
    #define SERVO2_NEUTRAL_POS -1
    #define SERVO3_NEUTRAL_POS -1
    #define UI_SERVO_CONTROL 0
    #define FEATURE_WATCHDOG 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define LANGUAGE_EN_ACTIVE 0
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 1
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "X3D XS CoreXY"
    #define UI_PRINTER_COMPANY "Damian"
    #define UI_ANIMATION 0
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 50
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA 188
    #define UI_SET_PRESET_HEATED_BED_TEMP_ABS 100
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS 232
    #define NUM_MOTOR_DRIVERS 0
    #endif
    "editMode": 2,
    "processor": 0,
    "baudrate": 250000,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 160,
    "yStepsPerMM": 160,
    "zStepsPerMM": 80,
    "xInvert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "zInvertEnable": 0,
    "extruder": [
    "id": 0,
    "heatManager": 1,
    "pidDriveMin": 40,
    "pidDriveMax": 230,
    "pidMax": 255,
    "sensorType": 8,
    "sensorPin": "TEMP_0_PIN",
    "heaterPin": "HEATER_0_PIN",
    "maxFeedrate": 50,
    "startFeedrate": 20,
    "invert": "0",
    "invertEnable": "0",
    "acceleration": 5000,
    "watchPeriod": 1,
    "pidP": 6.39,
    "pidI": 0.24,
    "pidD": 41.66,
    "advanceK": 0,
    "advanceL": 0,
    "waitRetractTemp": 150,
    "waitRetractUnits": 0,
    "waitRetract": 0,
    "stepsPerMM": 98.15,
    "coolerPin": -1,
    "coolerSpeed": 255,
    "selectCommands": "",
    "deselectCommands": "",
    "xOffset": 0,
    "yOffset": 0,
    "zOffset": 0,
    "xOffsetSteps": 0,
    "yOffsetSteps": 0,
    "zOffsetSteps": 0,
    "stepper": {
    "name": "Extruder 0",
    "step": "ORIG_E0_STEP_PIN",
    "dir": "ORIG_E0_DIR_PIN",
    "advanceBacklashSteps": 0,
    "decoupleTestPeriod": 12,
    "jamPin": -1,
    "jamPullup": "0"
    "uiLanguage": 9,
    "uiController": 0,
    "xMinEndstop": 2,
    "yMinEndstop": 2,
    "zMinEndstop": 0,
    "xMaxEndstop": 0,
    "yMaxEndstop": 0,
    "zMaxEndstop": 2,
    "motherboard": 33,
    "driveSystem": 1,
    "xMaxSpeed": 200,
    "xHomingSpeed": 20,
    "xTravelAcceleration": 500,
    "xPrintAcceleration": 500,
    "yMaxSpeed": 200,
    "yHomingSpeed": 20,
    "yTravelAcceleration": 500,
    "yPrintAcceleration": 500,
    "zMaxSpeed": 20,
    "zHomingSpeed": 5,
    "zTravelAcceleration": 100,
    "zPrintAcceleration": 100,
    "xMotor": {
    "name": "X motor",
    "step": "ORIG_X_STEP_PIN",
    "dir": "ORIG_X_DIR_PIN",
    "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
    "name": "Y motor",
    "step": "ORIG_Y_STEP_PIN",
    "dir": "ORIG_Y_DIR_PIN",
    "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
    "name": "Z motor",
    "step": "ORIG_Z_STEP_PIN",
    "dir": "ORIG_Z_DIR_PIN",
    "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 195,
    "yLength": 185,
    "zLength": 160,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": "1",
    "xEndstopBack": 1,
    "yEndstopBack": 1,
    "zEndstopBack": 0,
    "deltaDiagonalRod": 445,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 150,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "allowQuadstepping": "1",
    "doubleStepDelay": 1,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
    "name": "Extruder 1",
    "step": "ORIG_E1_STEP_PIN",
    "dir": "ORIG_E1_DIR_PIN",
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "mirrorZ3": "0",
    "mirrorZ3Motor": {
    "name": "Extruder 2",
    "step": "ORIG_E2_STEP_PIN",
    "dir": "ORIG_E2_DIR_PIN",
    "dittoPrinting": "0",
    "featureServos": "0",
    "servo0Pin": 11,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "0",
    "hasHeatedBed": "1",
    "enableZProbing": "0",
    "extrudeMaxLength": 160,
    "featureController": 11,
    "uiPrinterName": "X3D XS CoreXY",
    "uiPrinterCompany": "Damian",
    "uiPagesDuration": 4000,
    "uiAnimation": "0",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 2,
    "uiReverseEncoder": "0",
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "0",
    "uiPresetBedTempPLA": 50,
    "uiPresetBedABS": 100,
    "uiPresetExtruderPLA": 188,
    "uiPresetExtruderABS": 232,
    "uiMinHeatedBed": 30,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "maxBedTemperature": 120,
    "bedSensorType": 8,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeatManager": 0,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "userTable1": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "userTable2": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "featureFan2Control": "0",
    "fan2Pin": "ORIG_FAN2_PIN",
    "fanThermoPin": -1,
    "fanThermoMinPWM": 128,
    "fanThermoMaxPWM": 255,
    "fanThermoMinTemp": 45,
    "fanThermoMaxTemp": 60,
    "fanThermoThermistorPin": -1,
    "fanThermoThermistorType": 1,
    "scalePidToMax": 0,
    "zProbePin": -1,
    "zProbeBedDistance": 10,
    "zProbePullup": "0",
    "zProbeOnHigh": "0",
    "zProbeXOffset": 0,
    "zProbeYOffset": 0,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 2,
    "zProbeXYSpeed": 150,
    "zProbeHeight": 40,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "1",
    "zProbeX1": 20,
    "zProbeY1": 20,
    "zProbeX2": 160,
    "zProbeY2": 20,
    "zProbeX3": 100,
    "zProbeY3": 160,
    "zProbeSwitchingDistance": 1,
    "zProbeRepetitions": 1,
    "sdSupport": "0",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 2,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": -1,
    "mixingExtruder": "0",
    "featureAxisComp": "0",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "0",
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionEndDegrade": 1,
    "distortionXMin": 10,
    "distortionXMax": 180,
    "distortionYMin": 10,
    "distortionYMax": 180,
    "sdRunOnStop": "",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 0.6,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 0,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 0,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 1,
    "primaryPort": 0,
    "numMotorDrivers": 0,
    "motorDrivers": [
    "t": "None",
    "s": "",
    "invertDirection": "0",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "manualConfig": "",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "zProbeZOffsetMode": 0,
    "zProbeZOffset": 0,
    "uiBedCoating": "1",
    "langEN": "0",
    "langDE": "0",
    "langNL": "0",
    "langPT": "0",
    "langIT": "0",
    "langES": "0",
    "langFI": "0",
    "langSE": "0",
    "langFR": "0",
    "langCZ": "0",
    "langPL": "1",
    "langTR": "0",
    "accelerationFactorTop": 100,
    "bendingCorrectionA": 0,
    "bendingCorrectionB": 0,
    "bendingCorrectionC": 0,
    "preventZDisableOnStepperTimeout": "1",
    "supportLaser": "0",
    "laserPin": -1,
    "laserOnHigh": "1",
    "defaultPrinterMode": 0,
    "supportCNC": "0",
    "cncWaitOnEnable": 300,
    "cncWaitOnDisable": 0,
    "cncEnablePin": -1,
    "cncEnableWith": "1",
    "cncDirectionPin": -1,
    "cncDirectionCW": "1",
    "startupGCode": "",
    "jsonOutput": "0",
    "bedLevelingMethod": 0,
    "bedCorrectionMethod": 0,
    "bedLevelingGridSize": 5,
    "bedLevelingRepetitions": 5,
    "bedMotor1X": 0,
    "bedMotor1Y": 0,
    "bedMotor2X": 200,
    "bedMotor2Y": 0,
    "bedMotor3X": 100,
    "bedMotor3Y": 200,
    "zProbeRequiresHeating": "0",
    "zProbeMinTemperature": 150,
    "maxHalfstepInterval": 1999,
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": false,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 92.8,
    "primaryPortName": ""
  • Strange. Would it work as z min endstop and homign to z min? Just for testing and maybe a bit above floor testing so you fast enough disable printer if it is not detected.
  • edited February 2016
    I used my config from 0.92.3 to set new one 0.92.8. Maybe this is a problem?
    Homing is to X min, Y min and Z max and its works.
    I will check z min after work.
  • I think i know the problem. In printer.cpp line 214 you have
    #if FEATURE_Z_PROBE
    #if Z_PROBE_PIN == Z_MIN_PIN
    if(newRead & ENDSTOP_Z_MIN_ID) // prevent different results causing confusion
            newRead |= ENDSTOP_Z_PROBE_ID;
        if(Z_PROBE_ON_HIGH ? READ(Z_PROBE_PIN) : !READ(Z_PROBE_PIN))
    As you see there is a special case
    which is bad formulated as you have no min z endstop but the pin is defined. Correct test should be
    #if Z_PROBE_PIN == Z_MIN_PIN && MIN_HARDWARE_ENDSTOP_Z
    and then your problem should be gone.
  • Adding "&& MIN_HARDWARE_ENDSTOP_Z" fixed the state change issue on my Rambo powered delta printer without min endstops and Z probe switch connected to Z min pin S. Before, I had to set MIN_HARDWARE_ENDSTOP_Z to true to get the state change to work. Now I can set it to false to represent actual configuration.
  • Yes, it's works to me too. Thanks :-)
  • Great. I have already published it along with a other fix that disables preheating before z probe if not explicitly set.
