G-code view is cropped in browser view of Repetier Server
edited January 2016 in Repetier-Server
Not sure if it is actually a bug or not, but the in-browser g-code viewer seems to crop my files to a 135mm x 135mm square. I have it set up for my Rostock Max V2 with the bed shape set to circle and a radius of 135mm. The X and Y maxes and mins are set to 135 and -135 respectivly. Increasing these values (set to 500 to test) has no effect as the image is cut off at the same 135mm square.
  • Typical problem with wrong limits. Check printer configuration min xy is set to 0 in your case. So preview cuts objects at the limit. Set min limits to -135 and all is fine.
