Importing file from Revit to 3DMAX to Repetier...
Hi , can we use a Revit file, import it in 3Dmax clean it up and
then open it in Repetier ! It seems works but not quite , is my problem
because I need to have the entire file in one editble mesh or polylines or can I have segments in 3DMAX that are not even attached and open it in Repetier !
thanks
  • We can only read some triangle files, so in the end you need to export to a supported triangle format comtaining everything you want to print.
