Need some help in setting up Repetier host FW on my mini-Kossel
I'm trying to configure the Repetier firmware. I have some uncertainties with the followings, help will be appreciated!
#define EXT0_STEPS_PER_MM 413 //385
Not sure.
#define STEPS_PER_ROTATION 200
Not sure.
#define NUM_TEMPS_USERTHERMISTOR0
According to the original Merlin configuration file I'm using 100K thermistor - ATC Semitec 104GT-2 with 4.7k pullup
I'm not sure if the 28 values in the table are correct or not. I don't have a schematic for the controller board (RAMPS 1.3/RAMPS 1.4) so I don't know how does the voltage divider for the thermistor looks like. I guess I can work it out if I put a few minutes of effort into it and trace that part of the PCB, but perhaps the values are OK as is?
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN & other pin definitions
How can I make sure what pins are used, I can't find these definitions in the Merlin config file.
Thanks and merry Xmas! :)
  • // 8 is ATC Semitec 104GT-2
    set EXT0_SENSOR_TYPE 8
    EXT0_STEPS_PER_MM is the resolution of your extruder to move filament 1 mm in/out
    STEPS_PER_ROTATION is used to compute xyz resolution
    #define AXIS_STEPS_PER_MM ((float)(MICRO_STEPS * STEPS_PER_ROTATION) / PULLEY_CIRCUMFERENCE)
    #define XAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
    #define YAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
    #define ZAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
    You can also set AXIS_STEPS_PER_MM directly.
    I would also suggest better using our online config tool so your config can update with our updates. WIth github config you have to check for differences every update.
