[0.7.0 Linux] avrdude bug
When HEX firmware file upload is tried, error message appear that avrdude_bin do not exist.
ln -s avrdude avrdude_bin sloved issue as program avrdude is present not avrdude_bin.
  • But, even with this fix, upload hex still not doing the job.
    It now stops at "Uploading firmware binary ...".
    Is there any way to see command line it execute, so I can debug further ?
    P.S. 2560 has been used.
  • edited December 2015
    Log file:
    Before 'ln' and after.
    2000-01-08 14:14:28: LUA job firmwareUploadJob#{"filename":"/var/lib/Repetier-Server/tmp/tmplua0.hex","lang":"en","slug":"Kossel800","verbose":1.0000000000000000}
    2000-01-08 14:14:28: Connection closed: Kossel800
    2000-01-08 14:14:28: /usr/local/Repetier-Server/modules/firmware/bin/avrdude: line 4: /usr/local/Repetier-Server/modules/firmware/bin/avrdude_bin: No such file or directory
    2000-01-08 14:14:30: Connection started:Kossel800
    2000-01-08 14:14:30: Reset printer Kossel800
    2000-01-08 14:14:30: error: Reading serial conection failed: Operation canceled. Closing connection.
    2000-01-08 14:14:30: Connection closed: Kossel800
    2000-01-08 14:14:33: Connection started:Kossel800
    2000-01-08 14:14:33: Reset printer Kossel800
    2000-01-08 14:16:52: LUA job firmwareUploadJob#{"filename":"/var/lib/Repetier-Server/tmp/tmplua1.hex","lang":"en","slug":"Kossel800","verbose":1.0000000000000000}
    2000-01-08 14:16:52: Connection closed: Kossel800
    2000-01-08 14:21:03: LUA job firmwareUploadJob#{"filename":"/var/lib/Repetier-Server/tmp/tmplua2.hex","lang":"en","slug":"Kossel800","verbose":1.0000000000000000}
    2000-01-08 14:22:17: LUA job firmwareUploadJob#{"filename":"/var/lib/Repetier-Server/tmp/tmplua3.hex","lang":"en","slug":"Kossel800","verbose":1.0000000000000000}
    2000-01-08 14:24:04: LUA job firmwareUploadJob#{"filename":"/var/lib/Repetier-Server/tmp/tmplua4.hex","lang":"en","slug":"Kossel800","verbose":1.0000000000000000}
    2000-01-08 14:26:23: Connection started:Kossel800
    2000-01-08 14:26:23: Reset printer Kossel800
  • Oh, my mistake, looks like this avrdude is part of https://github.com/arduino/arduino-flash-tools
    So no ln was required, just it need all files from that project.
    Question is, should be there x32 or x64 used, my guess x32.
