Re Calibrate Z Axes
I have changed the Z axes to a lead screw from a threaded rod. But if I change the G code M92 or the values in EEPROM as soon as I reopen the the changes have gone back to the old settings.Am using V1.6.0
  • More importnant is here your firmware. Since repetier has no M92 you are using marlin? Maybe without eeprom support enabled so it looses data after restart?
