Ramps 1.4 And Full Graphic Smart Controller SD card Issue
Everything works great except the SD Card reader. Once I plug in the SD Card it goes supper slow and will not display what's on the card. It will display " SD Card Inserted". The card is partitioned to 200 MB FAT and has worked with other variants of Repetier on different machines. Can't help but think something is off in the firmware.
#define SDSUPPORT 0
#define SDCARDDETECT -1
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 11
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define UI_PRINTER_NAME "Ultimate"
#define UI_PRINTER_COMPANY "Matt Robison"
#define UI_ANIMATION 1
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 10
  • We haven't changed the sd card code for a long time. The slowdown is caused by automount and mount failure. Mounting fails but detect pin works so it tries to mount again eating all cpu time. Try a different cable at first. If one of the contacts is not good you get this.
  • ok thank you for the input I will verify the path's are good !
